Time Before: 0.02204 seconds
Time After: 0.02964 seconds
Time Taken: 0.00760 seconds
Time Before: 0.02974 seconds
Time After: 0.03016 seconds
Time Before: 0.03047 seconds
Time After: 0.03065 seconds
Time Before: 0.03169 seconds
Time After: 0.03372 seconds
Time Taken: 0.00203 seconds
Time Before: 0.03073 seconds
Time After: 0.03791 seconds
Time Taken: 0.00718 seconds
Time Before: 0.04726 seconds
Time After: 0.04769 seconds
Time Before: 0.05006 seconds
Time After: 0.05126 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04647 seconds
Time After: 0.05150 seconds
Time Taken: 0.00503 seconds
Memory After: 2,261.836 KB
Time Before: 0.09057 seconds
Time After: 0.09071 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.57025 seconds
Time After: 0.57191 seconds
Time Taken: 0.00166 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.57417392730713
Time Before: 0.58269 seconds
Time After: 0.58288 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.58534 seconds
Time After: 0.58759 seconds
Time Taken: 0.00226 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789059239, location = '/forums/private.php?do=newpm&explain=1&u=88239', badlocation = 1
Time Before: 0.60606 seconds
Time After: 0.60692 seconds
Time Taken: 0.00086 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.60493087768555 seconds with 9 queries, spending 0.0093858242034912 doing MySQL queries and 0.59554505348206 doing PHP things.
