Time Before: 0.03806 seconds
Time After: 0.04214 seconds
Time Taken: 0.00408 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.04222 seconds
Time After: 0.04265 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.04294 seconds
Time After: 0.04310 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.04397 seconds
Time After: 0.04731 seconds
Time Taken: 0.00334 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.04320 seconds
Time After: 0.05182 seconds
Time Taken: 0.00862 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05970 seconds
Time After: 0.05996 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.06261 seconds
Time After: 0.06462 seconds
Time Taken: 0.00200 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.05885 seconds
Time After: 0.06485 seconds
Time Taken: 0.00601 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.14464 seconds
Time After: 0.14491 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.53535 seconds
Time After: 0.53672 seconds
Time Taken: 0.00137 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.53902196884155
Time Before: 0.59073 seconds
Time After: 0.59093 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.59965 seconds
Time After: 0.60111 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=88338', badlocation = 1
Time Before: 0.63942 seconds
Time After: 0.63968 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.961 KB
Page generated in 0.63819909095764 seconds with 9 queries, spending 0.009756326675415 doing MySQL queries and 0.62844276428223 doing PHP things.
