Time Before: 0.02041 seconds
Time After: 0.02414 seconds
Time Taken: 0.00373 seconds
Time Before: 0.02425 seconds
Time After: 0.02467 seconds
Time Before: 0.02491 seconds
Time After: 0.02506 seconds
Time Before: 0.02595 seconds
Time After: 0.02807 seconds
Time Taken: 0.00212 seconds
Time Before: 0.02513 seconds
Time After: 0.03313 seconds
Time Taken: 0.00800 seconds
Time Before: 0.04304 seconds
Time After: 0.04345 seconds
Time Before: 0.04497 seconds
Time After: 0.04620 seconds
Time Before: 0.04227 seconds
Time After: 0.04639 seconds
Time Taken: 0.00411 seconds
Time Before: 0.07877 seconds
Time After: 0.07895 seconds
Time Before: 0.16945 seconds
Time After: 0.17068 seconds
End call of global.php: 0.17298889160156
Time Before: 0.17939 seconds
Time After: 0.17955 seconds
Time Before: 0.18193 seconds
Time After: 0.18339 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=88485', badlocation = 1
WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.19952 seconds
Time After: 0.19976 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.19849896430969 seconds with 9 queries, spending 0.0075948238372803 doing MySQL queries and 0.19090414047241 doing PHP things.
