Time Before: 0.00312 seconds
Time After: 0.00522 seconds
Time Taken: 0.00210 seconds
Time Before: 0.00531 seconds
Time After: 0.00582 seconds
Time Before: 0.00602 seconds
Time After: 0.00615 seconds
Time Before: 0.00693 seconds
Time After: 0.00903 seconds
Time Before: 0.00620 seconds
Time After: 0.01398 seconds
Time Taken: 0.00778 seconds
Time Before: 0.01757 seconds
Time After: 0.01798 seconds
Time Before: 0.02061 seconds
Time After: 0.02182 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01685 seconds
Time After: 0.02206 seconds
Time Taken: 0.00520 seconds
Memory After: 2,261.836 KB
Time Before: 0.03065 seconds
Time After: 0.03086 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.03759 seconds
Time After: 0.03899 seconds
Time Taken: 0.00140 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.04529 seconds
Time After: 0.04555 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.04851 seconds
Time After: 0.05142 seconds
Time Taken: 0.00291 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789078732, location = '/forums/private.php?do=newpm&explain=1&u=8849' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.07023 seconds
Time After: 0.07066 seconds
Memory Before: 4,287.586 KB
Memory After: 4,287.805 KB
