Time Before: 0.00139 seconds
Time After: 0.00192 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00198 seconds
Time After: 0.00250 seconds
Time Before: 0.00281 seconds
Time After: 0.00297 seconds
Time Before: 0.00391 seconds
Time After: 0.00706 seconds
Time Taken: 0.00315 seconds
Time Before: 0.00306 seconds
Time After: 0.01050 seconds
Time Taken: 0.00744 seconds
Time Before: 0.01318 seconds
Time After: 0.01358 seconds
Time Before: 0.01600 seconds
Time After: 0.01740 seconds
Time Taken: 0.00140 seconds
Time Before: 0.01244 seconds
Time After: 0.01759 seconds
Time Taken: 0.00516 seconds
Time Before: 0.02291 seconds
Time After: 0.02309 seconds
Time Before: 0.02523 seconds
Time After: 0.02648 seconds
Time Before: 0.02979 seconds
Time After: 0.02996 seconds
Time Before: 0.03306 seconds
Time After: 0.03453 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=88506', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.04712 seconds
Time After: 0.04739 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
