Time Before: 0.00149 seconds
Time After: 0.00195 seconds
Time Before: 0.00202 seconds
Time After: 0.00274 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00295 seconds
Time After: 0.00311 seconds
Time Before: 0.00384 seconds
Time After: 0.00659 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00316 seconds
Time After: 0.01000 seconds
Time Taken: 0.00684 seconds
Time Before: 0.01259 seconds
Time After: 0.01297 seconds
Time Before: 0.01556 seconds
Time After: 0.01683 seconds
Time Before: 0.01189 seconds
Time After: 0.01700 seconds
Time Taken: 0.00511 seconds
Time Before: 0.02242 seconds
Time After: 0.02265 seconds
Time Before: 0.02479 seconds
Time After: 0.02605 seconds
Time Before: 0.02904 seconds
Time After: 0.02916 seconds
Time Before: 0.03110 seconds
Time After: 0.03254 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=88604', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04492 seconds
Time After: 0.04515 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
