Time Before: 0.01528 seconds
Time After: 0.01902 seconds
Time Taken: 0.00374 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01914 seconds
Time After: 0.01960 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.01993 seconds
Time After: 0.02014 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02098 seconds
Time After: 0.02335 seconds
Time Taken: 0.00236 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02022 seconds
Time After: 0.02823 seconds
Time Taken: 0.00801 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03615 seconds
Time After: 0.03661 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.03931 seconds
Time After: 0.04054 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.03532 seconds
Time After: 0.04081 seconds
Time Taken: 0.00550 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.07493 seconds
Time After: 0.07506 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.10842 seconds
Time After: 0.10969 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
Time Before: 0.13290 seconds
Time After: 0.13304 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.13812 seconds
Time After: 0.13968 seconds
Time Taken: 0.00156 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=88611' WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.16772 seconds
Time After: 0.16803 seconds
Memory Before: 5,997.453 KB
Memory After: 5,997.695 KB
