Time Before: 0.00156 seconds
Time After: 0.00224 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00233 seconds
Time After: 0.00297 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00318 seconds
Time After: 0.00331 seconds
Time Before: 0.00402 seconds
Time After: 0.00660 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00336 seconds
Time After: 0.00995 seconds
Time Taken: 0.00659 seconds
Time Before: 0.01171 seconds
Time After: 0.01209 seconds
Time Before: 0.01341 seconds
Time After: 0.01484 seconds
Time Before: 0.01114 seconds
Time After: 0.01504 seconds
Time Taken: 0.00390 seconds
Time Before: 0.02050 seconds
Time After: 0.02067 seconds
Time Before: 0.02257 seconds
Time After: 0.02383 seconds
End call of global.php: 0.025722980499268
Time Before: 0.02699 seconds
Time After: 0.02712 seconds
Time Before: 0.02935 seconds
Time After: 0.03078 seconds
SET lastactivity = 1776755931, location = '/forums/private.php?do=newpm&explain=1&u=8870', badlocation = 1
Time Before: 0.04393 seconds
Time After: 0.04421 seconds
Memory Before: 4,288.563 KB
Memory After: 4,288.773 KB
Page generated in 0.043004035949707 seconds with 9 queries, spending 0.0084283351898193 doing MySQL queries and 0.034575700759888 doing PHP things.
