Time Before: 0.00434 seconds
Time After: 0.00653 seconds
Time Taken: 0.00220 seconds
Time Before: 0.00663 seconds
Time After: 0.00702 seconds
Time Before: 0.00724 seconds
Time After: 0.00740 seconds
Time Before: 0.00822 seconds
Time After: 0.01098 seconds
Time Taken: 0.00276 seconds
Time Before: 0.00746 seconds
Time After: 0.01630 seconds
Time Taken: 0.00883 seconds
Time Before: 0.01994 seconds
Time After: 0.02057 seconds
Time Taken: 0.00063 seconds
Time Before: 0.02332 seconds
Time After: 0.02459 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01921 seconds
Time After: 0.02481 seconds
Time Taken: 0.00561 seconds
Memory After: 2,261.719 KB
Time Before: 0.03432 seconds
Time After: 0.03449 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.03866 seconds
Time After: 0.03996 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.042389154434204
Time Before: 0.04525 seconds
Time After: 0.04542 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.04793 seconds
Time After: 0.04941 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=88921'
Time Before: 0.06960 seconds
Time After: 0.06987 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.068250179290771 seconds with 9 queries, spending 0.0085837841033936 doing MySQL queries and 0.059666395187378 doing PHP things.
