Time Before: 0.02188 seconds
Time After: 0.02830 seconds
Time Taken: 0.00642 seconds
Time Before: 0.02839 seconds
Time After: 0.02883 seconds
Time Before: 0.02915 seconds
Time After: 0.02928 seconds
Time Before: 0.03021 seconds
Time After: 0.03264 seconds
Time Taken: 0.00243 seconds
Time Before: 0.02935 seconds
Time After: 0.03785 seconds
Time Taken: 0.00850 seconds
Time Before: 0.04507 seconds
Time After: 0.04547 seconds
Time Before: 0.04839 seconds
Time After: 0.04963 seconds
Time Before: 0.04425 seconds
Time After: 0.04985 seconds
Time Taken: 0.00561 seconds
Time Before: 0.09047 seconds
Time After: 0.09060 seconds
Time Before: 0.10796 seconds
Time After: 0.10918 seconds
End call of global.php: 0.11163711547852
Time Before: 0.12020 seconds
Time After: 0.12036 seconds
Time Before: 0.12300 seconds
Time After: 0.12442 seconds
SET lastactivity = 1776532992, location = '/forums/private.php?do=newpm&explain=1&u=88951', badlocation = 1
Time Before: 0.14011 seconds
Time After: 0.14045 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.13911890983582 seconds with 9 queries, spending 0.0079152584075928 doing MySQL queries and 0.13120365142822 doing PHP things.
