Time Before: 0.00142 seconds
Time After: 0.00198 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00205 seconds
Time After: 0.00248 seconds
Time Before: 0.00297 seconds
Time After: 0.00353 seconds
Time Before: 0.00438 seconds
Time After: 0.00769 seconds
Time Taken: 0.00331 seconds
Time Before: 0.00358 seconds
Time After: 0.01242 seconds
Time Taken: 0.00885 seconds
Time Before: 0.01468 seconds
Time After: 0.01577 seconds
Time Taken: 0.00109 seconds
Time Before: 0.01777 seconds
Time After: 0.01893 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01378 seconds
Time After: 0.01914 seconds
Time Taken: 0.00536 seconds
Time Before: 0.02431 seconds
Time After: 0.02444 seconds
Time Before: 0.02656 seconds
Time After: 0.02878 seconds
Time Taken: 0.00222 seconds
End call of global.php: 0.031023979187012
Time Before: 0.03240 seconds
Time After: 0.03258 seconds
Time Before: 0.03469 seconds
Time After: 0.03612 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=88954'
Time Before: 0.04911 seconds
Time After: 0.04946 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.048155069351196 seconds with 9 queries, spending 0.010839223861694 doing MySQL queries and 0.037315845489502 doing PHP things.
