Time Before: 0.02252 seconds
Time After: 0.02897 seconds
Time Taken: 0.00645 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02906 seconds
Time After: 0.02951 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02973 seconds
Time After: 0.02990 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03084 seconds
Time After: 0.03347 seconds
Time Taken: 0.00263 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02998 seconds
Time After: 0.03750 seconds
Time Taken: 0.00753 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04666 seconds
Time After: 0.04710 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04993 seconds
Time After: 0.05137 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.04586 seconds
Time After: 0.05157 seconds
Time Taken: 0.00571 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.08159 seconds
Time After: 0.08176 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.13802 seconds
Time After: 0.13934 seconds
Time Taken: 0.00133 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
Time Before: 0.17083 seconds
Time After: 0.17099 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.17789 seconds
Time After: 0.17930 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=89030', badlocation = 1 WHERE sessionhash = 'c9ecef9835dff112a7666634a7a1b42a'
Time Before: 0.21046 seconds
Time After: 0.21075 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.961 KB
