Time Before: 0.01986 seconds
Time After: 0.02700 seconds
Time Taken: 0.00714 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02707 seconds
Time After: 0.02747 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02775 seconds
Time After: 0.02791 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02886 seconds
Time After: 0.03139 seconds
Time Taken: 0.00253 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02800 seconds
Time After: 0.03601 seconds
Time Taken: 0.00801 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04339 seconds
Time After: 0.04377 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04631 seconds
Time After: 0.04747 seconds
Time Taken: 0.00115 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.04272 seconds
Time After: 0.04768 seconds
Time Taken: 0.00496 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.08789 seconds
Time After: 0.08801 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.14057 seconds
Time After: 0.14179 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.14472699165344
Time Before: 0.17106 seconds
Time After: 0.17121 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.17734 seconds
Time After: 0.17882 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=89576', badlocation = 1
WHERE sessionhash = 'e0f0ca8e3048a6e309b58c7aba652665'
Time Before: 0.20385 seconds
Time After: 0.20416 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.961 KB
Page generated in 0.20273089408875 seconds with 9 queries, spending 0.0078957080841064 doing MySQL queries and 0.19483518600464 doing PHP things.
