Time Before: 0.00317 seconds
Time After: 0.00373 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00381 seconds
Time After: 0.00438 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00460 seconds
Time After: 0.00474 seconds
Time Before: 0.00544 seconds
Time After: 0.01031 seconds
Time Taken: 0.00487 seconds
Time Before: 0.00479 seconds
Time After: 0.01367 seconds
Time Taken: 0.00889 seconds
Time Before: 0.01713 seconds
Time After: 0.01754 seconds
Time Before: 0.02101 seconds
Time After: 0.02222 seconds
Time Before: 0.01484 seconds
Time After: 0.02239 seconds
Time Taken: 0.00755 seconds
Time Before: 0.02734 seconds
Time After: 0.02747 seconds
Time Before: 0.02963 seconds
Time After: 0.03084 seconds
End call of global.php: 0.032471179962158
Time Before: 0.03402 seconds
Time After: 0.03420 seconds
Time Before: 0.03761 seconds
Time After: 0.03906 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=89584', badlocation = 1
Time Before: 0.05557 seconds
Time After: 0.05689 seconds
Time Taken: 0.00132 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.054529190063477 seconds with 9 queries, spending 0.011487245559692 doing MySQL queries and 0.043041944503784 doing PHP things.
