Time Before: 0.01808 seconds
Time After: 0.02503 seconds
Time Taken: 0.00695 seconds
Time Before: 0.02513 seconds
Time After: 0.02551 seconds
Time Before: 0.02573 seconds
Time After: 0.02586 seconds
Time Before: 0.02672 seconds
Time After: 0.02862 seconds
Time Taken: 0.00190 seconds
Time Before: 0.02593 seconds
Time After: 0.03250 seconds
Time Taken: 0.00657 seconds
Time Before: 0.03872 seconds
Time After: 0.03924 seconds
Time Before: 0.04246 seconds
Time After: 0.04365 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03784 seconds
Time After: 0.04384 seconds
Time Taken: 0.00600 seconds
Memory After: 2,261.836 KB
Time Before: 0.06622 seconds
Time After: 0.06635 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.08303 seconds
Time After: 0.08432 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.09534 seconds
Time After: 0.09578 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.09867 seconds
Time After: 0.10021 seconds
Time Taken: 0.00154 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788972083, location = '/forums/private.php?do=newpm&explain=1&u=89672', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.11796 seconds
Time After: 0.11832 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
