Time Before: 0.02412 seconds
Time After: 0.03836 seconds
Time Taken: 0.01424 seconds
Time Before: 0.03846 seconds
Time After: 0.03895 seconds
Time Before: 0.03918 seconds
Time After: 0.03967 seconds
Time Before: 0.04053 seconds
Time After: 0.04271 seconds
Time Taken: 0.00218 seconds
Time Before: 0.03973 seconds
Time After: 0.04697 seconds
Time Taken: 0.00724 seconds
Time Before: 0.06157 seconds
Time After: 0.06210 seconds
Time Before: 0.06483 seconds
Time After: 0.06605 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.06085 seconds
Time After: 0.06623 seconds
Time Taken: 0.00538 seconds
Memory After: 2,261.836 KB
Time Before: 0.09374 seconds
Time After: 0.09387 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.12321 seconds
Time After: 0.12446 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.13792 seconds
Time After: 0.13809 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.14087 seconds
Time After: 0.14230 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789058799, location = '/forums/private.php?do=newpm&explain=1&u=89750' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.16440 seconds
Time After: 0.16477 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
