Time Before: 0.02777 seconds
Time After: 0.03674 seconds
Time Taken: 0.00897 seconds
Time Before: 0.03687 seconds
Time After: 0.03741 seconds
Time Taken: 0.00054 seconds
Time Before: 0.03770 seconds
Time After: 0.03786 seconds
Time Before: 0.03864 seconds
Time After: 0.04105 seconds
Time Taken: 0.00242 seconds
Time Before: 0.03793 seconds
Time After: 0.04530 seconds
Time Taken: 0.00737 seconds
Time Before: 0.05234 seconds
Time After: 0.05288 seconds
Time Before: 0.05563 seconds
Time After: 0.05685 seconds
Time Before: 0.05161 seconds
Time After: 0.05707 seconds
Time Taken: 0.00546 seconds
Time Before: 0.08660 seconds
Time After: 0.08685 seconds
Time Before: 0.10716 seconds
Time After: 0.10841 seconds
End call of global.php: 0.11082983016968
Time Before: 0.11640 seconds
Time After: 0.11657 seconds
Time Before: 0.11893 seconds
Time After: 0.12045 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1785288144, location = '/forums/private.php?do=newpm&explain=1&u=89767'
Time Before: 0.13803 seconds
Time After: 0.13835 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.13660788536072 seconds with 9 queries, spending 0.0083730220794678 doing MySQL queries and 0.12823486328125 doing PHP things.
