Time Before: 0.00170 seconds
Time After: 0.00233 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00242 seconds
Time After: 0.00304 seconds
Time Before: 0.00337 seconds
Time After: 0.00348 seconds
Time Before: 0.00418 seconds
Time After: 0.00657 seconds
Time Taken: 0.00239 seconds
Time Before: 0.00353 seconds
Time After: 0.00999 seconds
Time Taken: 0.00646 seconds
Time Before: 0.01176 seconds
Time After: 0.01217 seconds
Time Before: 0.01483 seconds
Time After: 0.01602 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01119 seconds
Time After: 0.01619 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02179 seconds
Time After: 0.02203 seconds
Time Before: 0.02430 seconds
Time After: 0.02559 seconds
End call of global.php: 0.028600931167603
Time Before: 0.03011 seconds
Time After: 0.03029 seconds
Time Before: 0.03347 seconds
Time After: 0.03486 seconds
Time Taken: 0.00139 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=89895'
Time Before: 0.04732 seconds
Time After: 0.04752 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.046416044235229 seconds with 9 queries, spending 0.0080506801605225 doing MySQL queries and 0.038365364074707 doing PHP things.
