Time Before: 0.00146 seconds
Time After: 0.00214 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00221 seconds
Time After: 0.00257 seconds
Time Before: 0.00291 seconds
Time After: 0.00305 seconds
Time Before: 0.00381 seconds
Time After: 0.00623 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00311 seconds
Time After: 0.00964 seconds
Time Taken: 0.00654 seconds
Time Before: 0.01162 seconds
Time After: 0.01201 seconds
Time Before: 0.01328 seconds
Time After: 0.01453 seconds
Time Before: 0.01104 seconds
Time After: 0.01470 seconds
Time Taken: 0.00366 seconds
Time Before: 0.02137 seconds
Time After: 0.02156 seconds
Time Before: 0.02352 seconds
Time After: 0.02477 seconds
End call of global.php: 0.026510000228882
Time Before: 0.02765 seconds
Time After: 0.02780 seconds
Time Before: 0.02974 seconds
Time After: 0.03121 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=90023', badlocation = 1
Time Before: 0.04356 seconds
Time After: 0.04379 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.042662143707275 seconds with 9 queries, spending 0.0078413486480713 doing MySQL queries and 0.034820795059204 doing PHP things.
