Time Before: 0.00839 seconds
Time After: 0.01192 seconds
Time Taken: 0.00353 seconds
Time Before: 0.01203 seconds
Time After: 0.01261 seconds
Time Taken: 0.00058 seconds
Time Before: 0.01293 seconds
Time After: 0.01308 seconds
Time Before: 0.01395 seconds
Time After: 0.01617 seconds
Time Taken: 0.00222 seconds
Time Before: 0.01315 seconds
Time After: 0.02107 seconds
Time Taken: 0.00792 seconds
Time Before: 0.02491 seconds
Time After: 0.02532 seconds
Time Before: 0.02839 seconds
Time After: 0.02961 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02426 seconds
Time After: 0.02986 seconds
Time Taken: 0.00560 seconds
Memory After: 2,261.836 KB
Time Before: 0.04618 seconds
Time After: 0.04633 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.05606 seconds
Time After: 0.05728 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.06440 seconds
Time After: 0.06455 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.06783 seconds
Time After: 0.06927 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789025545, location = '/forums/private.php?do=newpm&explain=1&u=9005' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.08424 seconds
Time After: 0.08453 seconds
Memory Before: 4,287.586 KB
Memory After: 4,287.805 KB
