Time Before: 0.00626 seconds
Time After: 0.00763 seconds
Time Taken: 0.00136 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.00771 seconds
Time After: 0.00817 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.00844 seconds
Time After: 0.00859 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.00937 seconds
Time After: 0.01174 seconds
Time Taken: 0.00238 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.00864 seconds
Time After: 0.01667 seconds
Time Taken: 0.00802 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.01975 seconds
Time After: 0.02019 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.02295 seconds
Time After: 0.02417 seconds
Memory Before: 2,770.195 KB
Memory After: 2,770.055 KB
Time Before: 0.01901 seconds
Time After: 0.02448 seconds
Time Taken: 0.00547 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.414 KB
Memory Used: 133.242 KB
Time Before: 0.03614 seconds
Time After: 0.03629 seconds
Memory Before: 3,436.539 KB
Memory After: 3,437.055 KB
Time Before: 0.04058 seconds
Time After: 0.04187 seconds
Memory Before: 3,524.336 KB
Memory After: 3,524.930 KB
End call of global.php: 0.044467926025391
Time Before: 0.04687 seconds
Time After: 0.04702 seconds
Memory Before: 4,162.242 KB
Memory After: 4,162.672 KB
Time Before: 0.04991 seconds
Time After: 0.05140 seconds
Memory Before: 4,443.805 KB
Memory After: 4,445.492 KB
SET lastactivity = 1780617288, location = '/forums/private.php?do=newpm&explain=1&u=90105', badlocation = 1
WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.06704 seconds
Time After: 0.06775 seconds
Time Taken: 0.00071 seconds
Memory Before: 4,922.375 KB
Memory After: 4,922.586 KB
Page generated in 0.066144943237305 seconds with 9 queries, spending 0.0084247589111328 doing MySQL queries and 0.057720184326172 doing PHP things.
