Time Before: 0.00133 seconds
Time After: 0.00179 seconds
Time Before: 0.00186 seconds
Time After: 0.00232 seconds
Time Before: 0.00254 seconds
Time After: 0.00275 seconds
Time Before: 0.00338 seconds
Time After: 0.00577 seconds
Time Taken: 0.00239 seconds
Time Before: 0.00280 seconds
Time After: 0.01104 seconds
Time Taken: 0.00824 seconds
Time Before: 0.01336 seconds
Time After: 0.01379 seconds
Time Before: 0.01631 seconds
Time After: 0.01753 seconds
Time Before: 0.01266 seconds
Time After: 0.01780 seconds
Time Taken: 0.00514 seconds
Time Before: 0.02347 seconds
Time After: 0.02372 seconds
Time Before: 0.02571 seconds
Time After: 0.02699 seconds
End call of global.php: 0.029378890991211
Time Before: 0.03102 seconds
Time After: 0.03124 seconds
Time Before: 0.03434 seconds
Time After: 0.03592 seconds
Time Taken: 0.00157 seconds
SET lastactivity = 1788978898, location = '/forums/private.php?do=newpm&explain=1&u=90343'
Time Before: 0.05090 seconds
Time After: 0.05125 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.049958944320679 seconds with 9 queries, spending 0.0083827972412109 doing MySQL queries and 0.041576147079468 doing PHP things.
