Time Before: 0.01837 seconds
Time After: 0.02377 seconds
Time Taken: 0.00541 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02390 seconds
Time After: 0.02441 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02470 seconds
Time After: 0.02483 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02576 seconds
Time After: 0.02830 seconds
Time Taken: 0.00254 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02492 seconds
Time After: 0.03238 seconds
Time Taken: 0.00747 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03812 seconds
Time After: 0.03863 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04135 seconds
Time After: 0.04257 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.03734 seconds
Time After: 0.04281 seconds
Time Taken: 0.00547 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.06547 seconds
Time After: 0.06563 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.10681 seconds
Time After: 0.10802 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.12588 seconds
Time After: 0.12605 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.13025 seconds
Time After: 0.13258 seconds
Time Taken: 0.00233 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1773205811, location = '/forums/private.php?do=newpm&explain=1&u=90491', badlocation = 1 WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.15696 seconds
Time After: 0.15728 seconds
Memory Before: 5,998.805 KB
Memory After: 5,999.016 KB
