Time Before: 0.00209 seconds
Time After: 0.00280 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00290 seconds
Time After: 0.00338 seconds
Time Before: 0.00363 seconds
Time After: 0.00378 seconds
Time Before: 0.00469 seconds
Time After: 0.00700 seconds
Time Taken: 0.00231 seconds
Time Before: 0.00385 seconds
Time After: 0.01137 seconds
Time Taken: 0.00752 seconds
Time Before: 0.01321 seconds
Time After: 0.01386 seconds
Time Taken: 0.00065 seconds
Time Before: 0.01657 seconds
Time After: 0.01779 seconds
Time Before: 0.01267 seconds
Time After: 0.01805 seconds
Time Taken: 0.00538 seconds
Time Before: 0.02461 seconds
Time After: 0.02480 seconds
Time Before: 0.02738 seconds
Time After: 0.02860 seconds
End call of global.php: 0.031208992004395
Time Before: 0.03265 seconds
Time After: 0.03286 seconds
Time Before: 0.03552 seconds
Time After: 0.03704 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=90513'
Time Before: 0.05070 seconds
Time After: 0.05096 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
Page generated in 0.049777030944824 seconds with 9 queries, spending 0.0082137584686279 doing MySQL queries and 0.041563272476196 doing PHP things.
