Time Before: 0.00157 seconds
Time After: 0.00222 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00229 seconds
Time After: 0.00279 seconds
Time Before: 0.00307 seconds
Time After: 0.00329 seconds
Time Before: 0.00419 seconds
Time After: 0.00690 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00336 seconds
Time After: 0.01182 seconds
Time Taken: 0.00846 seconds
Time Before: 0.01403 seconds
Time After: 0.01428 seconds
Time Before: 0.01583 seconds
Time After: 0.01701 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01333 seconds
Time After: 0.01728 seconds
Time Taken: 0.00395 seconds
Time Before: 0.02418 seconds
Time After: 0.02432 seconds
Time Before: 0.02640 seconds
Time After: 0.02763 seconds
Time Before: 0.03079 seconds
Time After: 0.03094 seconds
Time Before: 0.03362 seconds
Time After: 0.03508 seconds
UPDATE session SET lastactivity = 1776689843, location = '/forums/private.php?do=newpm&explain=1&u=90671', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.04837 seconds
Time After: 0.04862 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
