Time Before: 0.00148 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00246 seconds
Time Before: 0.00272 seconds
Time After: 0.00284 seconds
Time Before: 0.00367 seconds
Time After: 0.00644 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00292 seconds
Time After: 0.01076 seconds
Time Taken: 0.00784 seconds
Time Before: 0.01270 seconds
Time After: 0.01311 seconds
Time Before: 0.01581 seconds
Time After: 0.01702 seconds
Time Before: 0.01199 seconds
Time After: 0.01725 seconds
Time Taken: 0.00526 seconds
Time Before: 0.02393 seconds
Time After: 0.02407 seconds
Time Before: 0.02610 seconds
Time After: 0.02737 seconds
End call of global.php: 0.030205011367798
Time Before: 0.03179 seconds
Time After: 0.03194 seconds
Time Before: 0.03508 seconds
Time After: 0.03657 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=90673', badlocation = 1
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.05157 seconds
Time After: 0.05185 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
Page generated in 0.050615072250366 seconds with 9 queries, spending 0.0082881450653076 doing MySQL queries and 0.042326927185059 doing PHP things.
