Time Before: 0.00161 seconds
Time After: 0.00226 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00233 seconds
Time After: 0.00284 seconds
Time Before: 0.00311 seconds
Time After: 0.00335 seconds
Time Before: 0.00415 seconds
Time After: 0.00734 seconds
Time Taken: 0.00319 seconds
Time Before: 0.00342 seconds
Time After: 0.01133 seconds
Time Taken: 0.00791 seconds
Time Before: 0.01379 seconds
Time After: 0.01402 seconds
Time Before: 0.01646 seconds
Time After: 0.01765 seconds
Time Before: 0.01319 seconds
Time After: 0.01788 seconds
Time Taken: 0.00469 seconds
Time Before: 0.02441 seconds
Time After: 0.02452 seconds
Time Before: 0.02636 seconds
Time After: 0.02763 seconds
Time Before: 0.03056 seconds
Time After: 0.03070 seconds
Time Before: 0.03266 seconds
Time After: 0.03408 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=90731' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.04960 seconds
Time After: 0.04991 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
