Time Before: 0.02110 seconds
Time After: 0.02849 seconds
Time Taken: 0.00739 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.02857 seconds
Time After: 0.02912 seconds
Time Taken: 0.00056 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.02940 seconds
Time After: 0.02955 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.03041 seconds
Time After: 0.03364 seconds
Time Taken: 0.00323 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.02966 seconds
Time After: 0.03906 seconds
Time Taken: 0.00940 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.05122 seconds
Time After: 0.05161 seconds
Time Before: 0.05419 seconds
Time After: 0.05538 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05035 seconds
Time After: 0.05564 seconds
Time Taken: 0.00528 seconds
Memory After: 2,261.820 KB
Time Before: 0.11117 seconds
Time After: 0.11134 seconds
Memory Before: 2,815.414 KB
Memory After: 2,815.930 KB
Time Before: 0.12624 seconds
Time After: 0.12749 seconds
Memory Before: 2,903.719 KB
Memory After: 2,904.313 KB
Time Before: 0.14327 seconds
Time After: 0.14344 seconds
Memory Before: 3,540.484 KB
Memory After: 3,540.914 KB
Time Before: 0.14595 seconds
Time After: 0.14746 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,822.031 KB
Memory After: 3,823.703 KB
Memory Used: 1.672 KB
UPDATE session SET lastactivity = 1785415943, location = '/forums/private.php?do=newpm&explain=1&u=9080', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.16566 seconds
Time After: 0.16596 seconds
Memory Before: 4,296.141 KB
Memory After: 4,296.352 KB
