Time Before: 0.03078 seconds
Time After: 0.03664 seconds
Time Taken: 0.00587 seconds
Time Before: 0.03673 seconds
Time After: 0.03722 seconds
Time Before: 0.03746 seconds
Time After: 0.03765 seconds
Time Before: 0.03845 seconds
Time After: 0.04061 seconds
Time Taken: 0.00216 seconds
Time Before: 0.03770 seconds
Time After: 0.04449 seconds
Time Taken: 0.00679 seconds
Time Before: 0.05268 seconds
Time After: 0.05309 seconds
Time Before: 0.05643 seconds
Time After: 0.05760 seconds
Time Taken: 0.00118 seconds
Time Before: 0.05195 seconds
Time After: 0.05782 seconds
Time Before: 0.10022 seconds
Time After: 0.10060 seconds
Time Before: 0.11975 seconds
Time After: 0.12097 seconds
End call of global.php: 0.12340998649597
Time Before: 0.13045 seconds
Time After: 0.13060 seconds
Time Before: 0.13308 seconds
Time After: 0.13451 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=90803', badlocation = 1
Time Before: 0.15403 seconds
Time After: 0.15431 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
Page generated in 0.1530020236969 seconds with 9 queries, spending 0.0078961849212646 doing MySQL queries and 0.14510583877563 doing PHP things.
