Time Before: 0.02204 seconds
Time After: 0.03279 seconds
Time Taken: 0.01074 seconds
Time Before: 0.03291 seconds
Time After: 0.03352 seconds
Time Taken: 0.00061 seconds
Time Before: 0.03387 seconds
Time After: 0.03448 seconds
Time Before: 0.03613 seconds
Time After: 0.03906 seconds
Time Taken: 0.00293 seconds
Time Before: 0.03456 seconds
Time After: 0.04302 seconds
Time Taken: 0.00846 seconds
Time Before: 0.05383 seconds
Time After: 0.05423 seconds
Time Before: 0.05720 seconds
Time After: 0.05853 seconds
Time Taken: 0.00134 seconds
Time Before: 0.05295 seconds
Time After: 0.05877 seconds
Time Taken: 0.00582 seconds
Time Before: 0.09537 seconds
Time After: 0.09555 seconds
Time Before: 0.11791 seconds
Time After: 0.11926 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.12163901329041
Time Before: 0.13237 seconds
Time After: 0.13257 seconds
Time Before: 0.13525 seconds
Time After: 0.13677 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=9083'
Time Before: 0.15501 seconds
Time After: 0.15528 seconds
Memory Before: 4,910.797 KB
Memory After: 4,911.047 KB
Memory Used: 0.250 KB
Page generated in 0.15399789810181 seconds with 9 queries, spending 0.0094001293182373 doing MySQL queries and 0.14459776878357 doing PHP things.
