Time Before: 0.00327 seconds
Time After: 0.00390 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00400 seconds
Time After: 0.00441 seconds
Time Before: 0.00470 seconds
Time After: 0.00483 seconds
Time Before: 0.00582 seconds
Time After: 0.00926 seconds
Time Taken: 0.00344 seconds
Time Before: 0.00495 seconds
Time After: 0.01473 seconds
Time Taken: 0.00977 seconds
Time Before: 0.01712 seconds
Time After: 0.01731 seconds
Time Before: 0.01885 seconds
Time After: 0.02012 seconds
Time Before: 0.01638 seconds
Time After: 0.02032 seconds
Time Taken: 0.00394 seconds
Time Before: 0.02680 seconds
Time After: 0.02694 seconds
Time Before: 0.02921 seconds
Time After: 0.03072 seconds
Time Taken: 0.00151 seconds
End call of global.php: 0.033257007598877
Time Before: 0.03456 seconds
Time After: 0.03470 seconds
Time Before: 0.03684 seconds
Time After: 0.03867 seconds
Time Taken: 0.00183 seconds
SET lastactivity = 1776709038, location = '/forums/private.php?do=newpm&explain=1&u=90866'
Time Before: 0.05393 seconds
Time After: 0.05426 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.052558898925781 seconds with 9 queries, spending 0.0093765258789062 doing MySQL queries and 0.043182373046875 doing PHP things.
