Time Before: 0.02599 seconds
Time After: 0.03106 seconds
Time Taken: 0.00508 seconds
Time Before: 0.03117 seconds
Time After: 0.03180 seconds
Time Taken: 0.00063 seconds
Time Before: 0.03205 seconds
Time After: 0.03218 seconds
Time Before: 0.03307 seconds
Time After: 0.03535 seconds
Time Taken: 0.00228 seconds
Time Before: 0.03226 seconds
Time After: 0.03938 seconds
Time Taken: 0.00712 seconds
Time Before: 0.04954 seconds
Time After: 0.04998 seconds
Time Before: 0.05266 seconds
Time After: 0.05403 seconds
Time Taken: 0.00137 seconds
Time Before: 0.04883 seconds
Time After: 0.05426 seconds
Time Taken: 0.00542 seconds
Time Before: 0.09062 seconds
Time After: 0.09083 seconds
Time Before: 0.37888 seconds
Time After: 0.38025 seconds
End call of global.php: 0.38226580619812
Time Before: 0.38744 seconds
Time After: 0.38761 seconds
Time Before: 0.39019 seconds
Time After: 0.39162 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=90956', badlocation = 1
Time Before: 0.40872 seconds
Time After: 0.40904 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
Page generated in 0.40772390365601 seconds with 9 queries, spending 0.008366584777832 doing MySQL queries and 0.39935731887817 doing PHP things.
