Time Before: 0.01555 seconds
Time After: 0.02021 seconds
Time Taken: 0.00465 seconds
Time Before: 0.02032 seconds
Time After: 0.02152 seconds
Time Before: 0.02174 seconds
Time After: 0.02189 seconds
Time Before: 0.02258 seconds
Time After: 0.02662 seconds
Time Taken: 0.00404 seconds
Time Before: 0.02194 seconds
Time After: 0.03117 seconds
Time Taken: 0.00923 seconds
Time Before: 0.03720 seconds
Time After: 0.03776 seconds
Time Taken: 0.00056 seconds
Time Before: 0.04041 seconds
Time After: 0.04168 seconds
Time Before: 0.03652 seconds
Time After: 0.04194 seconds
Time Taken: 0.00542 seconds
Time Before: 0.07096 seconds
Time After: 0.07117 seconds
Time Before: 0.08385 seconds
Time After: 0.08512 seconds
End call of global.php: 0.087440013885498
Time Before: 0.09235 seconds
Time After: 0.09250 seconds
Time Before: 0.09519 seconds
Time After: 0.09668 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1789147665, location = '/forums/private.php?do=newpm&explain=1&u=90996'
Time Before: 0.11414 seconds
Time After: 0.11447 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.11294484138489 seconds with 9 queries, spending 0.010679483413696 doing MySQL queries and 0.10226535797119 doing PHP things.
