Time Before: 0.02623 seconds
Time After: 0.03247 seconds
Time Taken: 0.00625 seconds
Time Before: 0.03259 seconds
Time After: 0.03311 seconds
Time Before: 0.03335 seconds
Time After: 0.03353 seconds
Time Before: 0.03446 seconds
Time After: 0.03869 seconds
Time Taken: 0.00423 seconds
Time Before: 0.03362 seconds
Time After: 0.04296 seconds
Time Taken: 0.00934 seconds
Time Before: 0.05639 seconds
Time After: 0.05674 seconds
Time Before: 0.05821 seconds
Time After: 0.05938 seconds
Time Taken: 0.00118 seconds
Time Before: 0.05574 seconds
Time After: 0.05958 seconds
Time Taken: 0.00384 seconds
Time Before: 0.10516 seconds
Time After: 0.10529 seconds
Time Before: 0.12207 seconds
Time After: 0.12393 seconds
Time Taken: 0.00186 seconds
End call of global.php: 0.12640595436096
Time Before: 0.14005 seconds
Time After: 0.14024 seconds
Time Before: 0.14302 seconds
Time After: 0.14448 seconds
SET lastactivity = 1783117451, location = '/forums/private.php?do=newpm&explain=1&u=91012'
Time Before: 0.16611 seconds
Time After: 0.16648 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.16474390029907 seconds with 9 queries, spending 0.010477781295776 doing MySQL queries and 0.1542661190033 doing PHP things.
