Time Before: 0.00134 seconds
Time After: 0.00180 seconds
Time Before: 0.00187 seconds
Time After: 0.00232 seconds
Time Before: 0.00258 seconds
Time After: 0.00272 seconds
Time Before: 0.00356 seconds
Time After: 0.00618 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00280 seconds
Time After: 0.00962 seconds
Time Taken: 0.00681 seconds
Time Before: 0.01156 seconds
Time After: 0.01194 seconds
Time Before: 0.01487 seconds
Time After: 0.01612 seconds
Time Before: 0.01087 seconds
Time After: 0.01637 seconds
Time Taken: 0.00550 seconds
Time Before: 0.02309 seconds
Time After: 0.02328 seconds
Time Before: 0.02549 seconds
Time After: 0.02675 seconds
End call of global.php: 0.028538942337036
Time Before: 0.02987 seconds
Time After: 0.03003 seconds
Time Before: 0.03227 seconds
Time After: 0.03374 seconds
SET lastactivity = 1776644933, location = '/forums/private.php?do=newpm&explain=1&u=91104'
Time Before: 0.04768 seconds
Time After: 0.04795 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.046693086624146 seconds with 9 queries, spending 0.0081911087036133 doing MySQL queries and 0.038501977920532 doing PHP things.
