Time Before: 0.00145 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00247 seconds
Time Before: 0.00272 seconds
Time After: 0.00284 seconds
Time Before: 0.00351 seconds
Time After: 0.00577 seconds
Time Taken: 0.00226 seconds
Time Before: 0.00288 seconds
Time After: 0.00953 seconds
Time Taken: 0.00665 seconds
Time Before: 0.01144 seconds
Time After: 0.01197 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01464 seconds
Time After: 0.01583 seconds
Time Before: 0.01079 seconds
Time After: 0.01602 seconds
Time Taken: 0.00523 seconds
Time Before: 0.02099 seconds
Time After: 0.02112 seconds
Time Before: 0.02334 seconds
Time After: 0.02489 seconds
Time Taken: 0.00155 seconds
End call of global.php: 0.026506185531616
Time Before: 0.02794 seconds
Time After: 0.02814 seconds
Time Before: 0.03020 seconds
Time After: 0.03165 seconds
SET lastactivity = 1783148119, location = '/forums/private.php?do=newpm&explain=1&u=91202', badlocation = 1
Time Before: 0.04425 seconds
Time After: 0.04472 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.043329000473022 seconds with 9 queries, spending 0.0083775520324707 doing MySQL queries and 0.034951448440552 doing PHP things.
