Time Before: 0.00184 seconds
Time After: 0.00242 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00252 seconds
Time After: 0.00310 seconds
Time Before: 0.00342 seconds
Time After: 0.00361 seconds
Time Before: 0.00456 seconds
Time After: 0.00695 seconds
Time Taken: 0.00239 seconds
Time Before: 0.00369 seconds
Time After: 0.01041 seconds
Time Taken: 0.00672 seconds
Time Before: 0.01255 seconds
Time After: 0.01300 seconds
Time Before: 0.01605 seconds
Time After: 0.01724 seconds
Time Before: 0.01178 seconds
Time After: 0.01742 seconds
Time Taken: 0.00564 seconds
Time Before: 0.02246 seconds
Time After: 0.02259 seconds
Time Before: 0.02507 seconds
Time After: 0.02713 seconds
Time Taken: 0.00205 seconds
Time Before: 0.03001 seconds
Time After: 0.03018 seconds
Time Before: 0.03220 seconds
Time After: 0.03361 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=9126', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.04578 seconds
Time After: 0.04612 seconds
Memory Before: 4,288.008 KB
Memory After: 4,288.234 KB
