Time Before: 0.00154 seconds
Time After: 0.00209 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00215 seconds
Time After: 0.00271 seconds
Time Before: 0.00293 seconds
Time After: 0.00306 seconds
Time Before: 0.00376 seconds
Time After: 0.00630 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00311 seconds
Time After: 0.00979 seconds
Time Taken: 0.00668 seconds
Time Before: 0.01229 seconds
Time After: 0.01270 seconds
Time Before: 0.01530 seconds
Time After: 0.01656 seconds
Time Before: 0.01153 seconds
Time After: 0.01679 seconds
Time Taken: 0.00526 seconds
Time Before: 0.02263 seconds
Time After: 0.02279 seconds
Time Before: 0.02509 seconds
Time After: 0.02652 seconds
End call of global.php: 0.028218984603882
Time Before: 0.02932 seconds
Time After: 0.02948 seconds
Time Before: 0.03144 seconds
Time After: 0.03288 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=91361'
Time Before: 0.04682 seconds
Time After: 0.04713 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.045901775360107 seconds with 9 queries, spending 0.0083932876586914 doing MySQL queries and 0.037508487701416 doing PHP things.
