Time Before: 0.00982 seconds
Time After: 0.01318 seconds
Time Taken: 0.00336 seconds
Time Before: 0.01328 seconds
Time After: 0.01374 seconds
Time Before: 0.01399 seconds
Time After: 0.01415 seconds
Time Before: 0.01497 seconds
Time After: 0.01748 seconds
Time Taken: 0.00252 seconds
Time Before: 0.01424 seconds
Time After: 0.02159 seconds
Time Taken: 0.00735 seconds
Time Before: 0.02569 seconds
Time After: 0.02593 seconds
Time Before: 0.02733 seconds
Time After: 0.02857 seconds
Time Before: 0.02500 seconds
Time After: 0.02882 seconds
Time Taken: 0.00381 seconds
Time Before: 0.04488 seconds
Time After: 0.04504 seconds
Time Before: 0.05240 seconds
Time After: 0.05365 seconds
End call of global.php: 0.055635929107666
Time Before: 0.06117 seconds
Time After: 0.06134 seconds
Time Before: 0.06372 seconds
Time After: 0.06520 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=91574', badlocation = 1
Time Before: 0.08052 seconds
Time After: 0.08080 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.079596996307373 seconds with 9 queries, spending 0.0079421997070312 doing MySQL queries and 0.071654796600342 doing PHP things.
