Time Before: 0.02862 seconds
Time After: 0.03788 seconds
Time Taken: 0.00927 seconds
Time Before: 0.03801 seconds
Time After: 0.03968 seconds
Time Taken: 0.00168 seconds
Time Before: 0.03994 seconds
Time After: 0.04006 seconds
Time Before: 0.04085 seconds
Time After: 0.04274 seconds
Time Taken: 0.00189 seconds
Time Before: 0.04013 seconds
Time After: 0.04709 seconds
Time Taken: 0.00695 seconds
Time Before: 0.05781 seconds
Time After: 0.05824 seconds
Time Before: 0.06103 seconds
Time After: 0.06224 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.05715 seconds
Time After: 0.06244 seconds
Time Taken: 0.00529 seconds
Memory After: 2,261.836 KB
Time Before: 0.11652 seconds
Time After: 0.11684 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"41.47,\";s:9:\"lastcheck\";i:1788946197;}', 1)Time Before: 0.13375 seconds
Time After: 0.13402 seconds
Memory Before: 2,816.625 KB
Memory After: 2,816.875 KB
Memory Used: 0.250 KB
Time Before: 0.15722 seconds
Time After: 0.15870 seconds
Memory Before: 2,903.930 KB
Memory After: 2,904.523 KB
Time Before: 0.17202 seconds
Time After: 0.17233 seconds
Memory Before: 3,540.734 KB
Memory After: 3,541.164 KB
Time Before: 0.17498 seconds
Time After: 0.17643 seconds
Memory Before: 3,822.313 KB
Memory After: 3,824.000 KB
UPDATE session SET lastactivity = 1788946197, location = '/forums/private.php?do=newpm&explain=1&u=91579' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.19430 seconds
Time After: 0.19468 seconds
Memory Before: 4,296.148 KB
Memory After: 4,296.375 KB
