Time Before: 0.00135 seconds
Time After: 0.00181 seconds
Time Before: 0.00188 seconds
Time After: 0.00233 seconds
Time Before: 0.00255 seconds
Time After: 0.00270 seconds
Time Before: 0.00351 seconds
Time After: 0.00603 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00275 seconds
Time After: 0.01093 seconds
Time Taken: 0.00818 seconds
Time Before: 0.01278 seconds
Time After: 0.01316 seconds
Time Before: 0.01552 seconds
Time After: 0.01674 seconds
Time Before: 0.01215 seconds
Time After: 0.01692 seconds
Time Taken: 0.00477 seconds
Time Before: 0.02408 seconds
Time After: 0.02429 seconds
Time Before: 0.02697 seconds
Time After: 0.02824 seconds
Time Before: 0.03146 seconds
Time After: 0.03167 seconds
Time Before: 0.03374 seconds
Time After: 0.03513 seconds
Time Taken: 0.00139 seconds
UPDATE session SET lastactivity = 1789033148, location = '/forums/private.php?do=newpm&explain=1&u=91616' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04762 seconds
Time After: 0.04795 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
