Time Before: 0.00158 seconds
Time After: 0.00221 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00228 seconds
Time After: 0.00291 seconds
Time Before: 0.00316 seconds
Time After: 0.00332 seconds
Time Before: 0.00416 seconds
Time After: 0.00660 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00339 seconds
Time After: 0.01127 seconds
Time Taken: 0.00788 seconds
Time Before: 0.01315 seconds
Time After: 0.01358 seconds
Time Before: 0.01503 seconds
Time After: 0.01625 seconds
Time Before: 0.01254 seconds
Time After: 0.01643 seconds
Time Taken: 0.00389 seconds
Time Before: 0.02207 seconds
Time After: 0.02221 seconds
Time Before: 0.02411 seconds
Time After: 0.02537 seconds
Time Before: 0.02854 seconds
Time After: 0.02869 seconds
Time Before: 0.03080 seconds
Time After: 0.03236 seconds
Time Taken: 0.00157 seconds
UPDATE session SET lastactivity = 1782975731, location = '/forums/private.php?do=newpm&explain=1&u=91642' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.04985 seconds
Time After: 0.05014 seconds
Memory Before: 4,911.945 KB
Memory After: 4,912.172 KB
