Time Before: 0.01139 seconds
Time After: 0.01727 seconds
Time Taken: 0.00588 seconds
Time Before: 0.01737 seconds
Time After: 0.01784 seconds
Time Before: 0.01809 seconds
Time After: 0.01824 seconds
Time Before: 0.01912 seconds
Time After: 0.02147 seconds
Time Taken: 0.00234 seconds
Time Before: 0.01832 seconds
Time After: 0.02641 seconds
Time Taken: 0.00809 seconds
Time Before: 0.03796 seconds
Time After: 0.03844 seconds
Time Before: 0.04106 seconds
Time After: 0.04226 seconds
Time Before: 0.03541 seconds
Time After: 0.04247 seconds
Time Taken: 0.00706 seconds
Time Before: 0.07357 seconds
Time After: 0.07374 seconds
Time Before: 0.09377 seconds
Time After: 0.09508 seconds
Time Taken: 0.00131 seconds
Time Before: 0.10365 seconds
Time After: 0.10389 seconds
Time Before: 0.10670 seconds
Time After: 0.10816 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=91675' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.12794 seconds
Time After: 0.12826 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
