Time Before: 0.01834 seconds
Time After: 0.02507 seconds
Time Taken: 0.00672 seconds
Time Before: 0.02515 seconds
Time After: 0.02560 seconds
Time Before: 0.02588 seconds
Time After: 0.02601 seconds
Time Before: 0.02681 seconds
Time After: 0.02903 seconds
Time Taken: 0.00222 seconds
Time Before: 0.02607 seconds
Time After: 0.03411 seconds
Time Taken: 0.00805 seconds
Time Before: 0.04125 seconds
Time After: 0.04171 seconds
Time Before: 0.04426 seconds
Time After: 0.04543 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04057 seconds
Time After: 0.04567 seconds
Time Taken: 0.00510 seconds
Memory After: 2,261.836 KB
Time Before: 0.07324 seconds
Time After: 0.07338 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.08902 seconds
Time After: 0.09031 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.09813 seconds
Time After: 0.09834 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.10116 seconds
Time After: 0.10338 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788893315, location = '/forums/private.php?do=newpm&explain=1&u=91703' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.12318 seconds
Time After: 0.12351 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
