Time Before: 0.02109 seconds
Time After: 0.03021 seconds
Time Taken: 0.00912 seconds
Time Before: 0.03030 seconds
Time After: 0.03070 seconds
Time Before: 0.03094 seconds
Time After: 0.03107 seconds
Time Before: 0.03183 seconds
Time After: 0.03384 seconds
Time Taken: 0.00202 seconds
Time Before: 0.03114 seconds
Time After: 0.03792 seconds
Time Taken: 0.00678 seconds
Time Before: 0.04303 seconds
Time After: 0.04343 seconds
Time Before: 0.04500 seconds
Time After: 0.04620 seconds
Time Before: 0.04223 seconds
Time After: 0.04644 seconds
Time Taken: 0.00421 seconds
Time Before: 0.09538 seconds
Time After: 0.09554 seconds
Time Before: 0.10770 seconds
Time After: 0.10893 seconds
Time Before: 0.12028 seconds
Time After: 0.12042 seconds
Time Before: 0.12283 seconds
Time After: 0.12501 seconds
Time Taken: 0.00218 seconds
UPDATE session SET lastactivity = 1783045649, location = '/forums/private.php?do=newpm&explain=1&u=91722' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.14440 seconds
Time After: 0.14468 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
