Time Before: 0.00508 seconds
Time After: 0.00764 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00771 seconds
Time After: 0.00930 seconds
Time Taken: 0.00159 seconds
Time Before: 0.00954 seconds
Time After: 0.00967 seconds
Time Before: 0.01048 seconds
Time After: 0.01314 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00974 seconds
Time After: 0.01710 seconds
Time Taken: 0.00736 seconds
Time Before: 0.02141 seconds
Time After: 0.02178 seconds
Time Before: 0.02421 seconds
Time After: 0.02568 seconds
Time Before: 0.02079 seconds
Time After: 0.02587 seconds
Time Taken: 0.00508 seconds
Time Before: 0.03587 seconds
Time After: 0.03609 seconds
Time Before: 0.13165 seconds
Time After: 0.13293 seconds
Time Before: 0.14039 seconds
Time After: 0.14057 seconds
Time Before: 0.14375 seconds
Time After: 0.14522 seconds
UPDATE session SET lastactivity = 1789088353, location = '/forums/private.php?do=newpm&explain=1&u=91745', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.16294 seconds
Time After: 0.16339 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
