Time Before: 0.02164 seconds
Time After: 0.02682 seconds
Time Taken: 0.00518 seconds
Time Before: 0.02692 seconds
Time After: 0.02741 seconds
Time Before: 0.02765 seconds
Time After: 0.02786 seconds
Time Before: 0.02865 seconds
Time After: 0.03101 seconds
Time Taken: 0.00236 seconds
Time Before: 0.02791 seconds
Time After: 0.03529 seconds
Time Taken: 0.00738 seconds
Time Before: 0.04419 seconds
Time After: 0.04456 seconds
Time Before: 0.04715 seconds
Time After: 0.04840 seconds
Time Before: 0.04353 seconds
Time After: 0.04864 seconds
Time Taken: 0.00511 seconds
Time Before: 0.08771 seconds
Time After: 0.08790 seconds
Time Before: 0.10352 seconds
Time After: 0.10477 seconds
End call of global.php: 0.10719180107117
Time Before: 0.11811 seconds
Time After: 0.11831 seconds
Time Before: 0.12081 seconds
Time After: 0.12229 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=91784'
Time Before: 0.13993 seconds
Time After: 0.14022 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.13877487182617 seconds with 9 queries, spending 0.0080881118774414 doing MySQL queries and 0.13068675994873 doing PHP things.
