Time Before: 0.02231 seconds
Time After: 0.03008 seconds
Time Taken: 0.00777 seconds
Time Before: 0.03015 seconds
Time After: 0.03067 seconds
Time Before: 0.03092 seconds
Time After: 0.03109 seconds
Time Before: 0.03188 seconds
Time After: 0.03423 seconds
Time Taken: 0.00235 seconds
Time Before: 0.03114 seconds
Time After: 0.03796 seconds
Time Taken: 0.00682 seconds
Time Before: 0.04657 seconds
Time After: 0.04706 seconds
Time Before: 0.05010 seconds
Time After: 0.05133 seconds
Time Before: 0.04576 seconds
Time After: 0.05155 seconds
Time Taken: 0.00579 seconds
Time Before: 0.09966 seconds
Time After: 0.09979 seconds
Time Before: 0.11445 seconds
Time After: 0.11568 seconds
Time Before: 0.12599 seconds
Time After: 0.12612 seconds
Time Before: 0.12884 seconds
Time After: 0.13040 seconds
Time Taken: 0.00156 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=91801', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.15083 seconds
Time After: 0.15120 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
