Time Before: 0.00141 seconds
Time After: 0.00188 seconds
Time Before: 0.00195 seconds
Time After: 0.00236 seconds
Time Before: 0.00258 seconds
Time After: 0.00275 seconds
Time Before: 0.00359 seconds
Time After: 0.00622 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00283 seconds
Time After: 0.01110 seconds
Time Taken: 0.00827 seconds
Time Before: 0.01362 seconds
Time After: 0.01403 seconds
Time Before: 0.01576 seconds
Time After: 0.01694 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01282 seconds
Time After: 0.01713 seconds
Time Taken: 0.00430 seconds
Time Before: 0.02326 seconds
Time After: 0.02340 seconds
Time Before: 0.02520 seconds
Time After: 0.02641 seconds
Time Before: 0.02953 seconds
Time After: 0.02969 seconds
Time Before: 0.03275 seconds
Time After: 0.03426 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=91811' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.04758 seconds
Time After: 0.04785 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
