Time Before: 0.01117 seconds
Time After: 0.01512 seconds
Time Taken: 0.00395 seconds
Time Before: 0.01523 seconds
Time After: 0.01567 seconds
Time Before: 0.01600 seconds
Time After: 0.01617 seconds
Time Before: 0.01704 seconds
Time After: 0.01932 seconds
Time Taken: 0.00229 seconds
Time Before: 0.01622 seconds
Time After: 0.02318 seconds
Time Taken: 0.00695 seconds
Time Before: 0.02838 seconds
Time After: 0.02878 seconds
Time Before: 0.03168 seconds
Time After: 0.03290 seconds
Time Before: 0.02778 seconds
Time After: 0.03313 seconds
Time Taken: 0.00535 seconds
Time Before: 0.05236 seconds
Time After: 0.05251 seconds
Time Before: 0.06022 seconds
Time After: 0.06145 seconds
End call of global.php: 0.063561916351318
Time Before: 0.06836 seconds
Time After: 0.06852 seconds
Time Before: 0.07082 seconds
Time After: 0.07231 seconds
SET lastactivity = 1785377103, location = '/forums/private.php?do=newpm&explain=1&u=91812'
Time Before: 0.08992 seconds
Time After: 0.09016 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.088711977005005 seconds with 9 queries, spending 0.0077738761901855 doing MySQL queries and 0.080938100814819 doing PHP things.
